SignUp Now!I'm having my gnx clone painted and was wondering what color the vents should be? They are cheap plastic ones bought at BG last year. Should they be satin black like the headlight bezels or something more shiny to match the paint? Thanks!
Thanks!satin black
No thanks!Hot pink
What color are they currently?
If they are the original molded stain black color just leave them as-is and install them.
Post a picture of them if you can. I am not a big fan of painting the plastic parts on our cars. (Headlight bezels, Vents, Taillight trim) I find they have a much better finish un-painted just like when they came from the factory.
Hot pink
Have your painter go ahead and shoot them with same black base of the car. Then instead of using the high gloss clear, have them use a low gloss clear. With many modern clears this is an additive that can be mixed in the unused high gloss at the end of a painting session. This will give you reliable UV protection and durable paint for cleaning and the heat you are going to pull through them from under the hood.
Good luck on the project.
im confused...is that pink poka dots with black or black poka dots with pink
