Cometic install
Alaskabuick
Getting ready to install my heads with cometic gaskets.
I have read many posts on this and decided to use the copper coat between the layers.
One question I have: Do you only use the copper coat between the layers of gasket or do you apply it to the top and bottem of the gasket as well?
In other words should I apply a layer of the copper coat between the gasket and the head and the gasket and the block?
Additionally, I am using ARP studs. What should I torque the heads at? GN1 Aluminum heads.
thanks,
Dennis
Cometics
Dennis
I thought we covered this but maybe that was another conversation.
Please don't hesitate to give me a call and we can go over your install
DAN
DLS Engine Development
219-956-3653
I coated the top, bottom, and in between layers on mine. Using the .060 ones.
No issues yet in 4 months. Bout 35-40 1/4 track passes.
If Dan is building the motor.. go with his advice.
HTH
install gastkets
V6gofast said:
Dennis
DAN
219-956-3653
Dan, I dont think we went over it in much detail? I just tried calling you.
Im at home 907-458-2166, Thanks
Den
