jhanson1750
just a 10th quicker
- Apr 24, 2005
Well folks I got my 86' up and running yesterday.
I installed cometics and they are leak free. Here is the procedure I used.
1: Seperate layers from one another. (remove rivets)
2: Spray BOTH sides of all layers (should be 3) with Copper coat
3: Install and torque
4: Wait two (2) days
5: One at a time in the torque sequence loosen the studs (or bolts) 1/4 turn and re torque in a smooth even pull!
6: Wait 3 days
7: See step 5
8: Complete assembly and you are ready to go.
This is assuming you have flat decks on the heads and the block. I think the copper coat will deal with some minor imperfections.
I ran mine through 3 heat cycles and am still good. If that change I will post back.
6: Wait 3 days
7: See step 5
