Comp cam specs from ~2004?
GO 4LO
I recently purchased a car with a Stage 2 engine that was assembled ~12 years ago. I'm trying to figure out all the details on the build, but the engine builder did not have records back that far and the prior owner had only partial records. First, I'm trying to track down some info on the cam. We think it's a Comp Cam, either 230 or 236 @ .050. Does anybody have the rest of the cam specs for Comp's "standard" Buick offerings back then? Thanks.
Chris
There really isn't any standard offerings but they have lobe profiles that are usually noted on the back of the cam. So a 230 or 236 can be any number of different lobe profiles. If you measure the lift at the lifter you can probably zero in on a few.
AG.
