Nov 5, 2002 #1 K KWIKR 1 Active Member Joined May 25, 2001 Messages 1,885 Anybody know what the following CR will be ? TTA Pistons , GN Heads , Single Steel Shim HG = TTA pistons , GN Heads , Double Steel Shim HG = **Thanks**
Nov 5, 2002 #2 T trading t/a I'm Angry!!!!! Joined Aug 6, 2001 Messages 1,120 Add .1 in compression for every 1 cc difference between the gn heads and TTA heads.
Nov 8, 2002 #3 T trading t/a I'm Angry!!!!! Joined Aug 6, 2001 Messages 1,120 I would say around 8.0-8.3 to 1 depending on the thickness of the head gasket. Or you could have the heads milled to bring the compression back to normal.......
Nov 8, 2002 #4 K KWIKR 1 Active Member Joined May 25, 2001 Messages 1,885 I was planning on two steel shim gaskets per-side .
