complete 3.8 stage 2 stroker short block
richardv6
i purchased a stage2 3.8 shortblock from freind and took apart for inspection and all looks perfect had local machine shop check over,did light hone on cylinders and has fresh bearings,motor contains a bms 3.590 stroke crank,6"carrillo rods and je pistons.motor is .020 over.double rollor chain,solid roller cam and lifters,cam is 232/232.new front cover set of push rods.and pump,all arp fasteners the block has had some a repair in its history,fixed crack between freeze plugs on pass side which was common .but was told it was heat treated and properly repaired.and motor has been ran many times afterwards.i decided to put a oncenter stage 2 motor in my car and dont need this laying around.these motors are rare and would make a perfect streetcar motor.i am wanting $5500 for all.i took pics of parts apart and now all is reassembled.lifters labled were they come out.
So this is an Offcenter Motor? What heads an intake are needed?
Off center.use stage one heads or gn1 14 bolt style heads.and stock intake or gn1
i wish i would have waited on my 109 build i would have jumped all on this...good luck with the sale.............Bob
Shipping is possible,.i work at a dealership so it would not be hard.if interested give me a call..828-442-5950
Im not one to post in peoples ads to add nothing, but since this is probably sold. That was a KILLER deal. I almost bought it for a backup,but mywife would of had a stroke.
i do have a deposit on it and awaiting rest.depends on how long it takes to recieve remainder.i will post results..
