Complete 3.8 stroker
deleonl
N.S.D.Q
3.8L Buick block (249 Cubic inch)
270-Stroker 4340 billet crank (3.625)
Molnar Technologies 5.960 rods
Pro-Gram engineering billet main caps
RJC Girdle
Front cover with high volume oil pump
BHJ Internal balance harmonic balancer
J/W flexplate
Diamond pistons with total seal rings (.20 Bore)
212/212 roller cam
Iron Kenne Bell ported heads with large values
1.65 T and D shaft roller rockers
Accufab 70MM TB and matching Plenum
GN1 valve covers
Stock ported intake
Stock fuel rails
Seiman low-z 83lb injectors with modified ECM
The motor will come with everything you see in the picture to include an ECM, two turbo tweak chips – one for alky and the other a 91 street chip. This motor is complete and ready to drop in. I can remove AC unit, alternator, and PS pump if you don’t need them. I have all the paperwork for the build.
Located in San Antonio, TX
Willing to ship at buyers expense.
8k obo
Quick history of the motor. Built in 2018, ran for about 2k with no issues. Pulled and replaced with a built turbo LS1. Short block was built by a shop in Houston, TX.
Wow very clean and cool. There is a roller GN in the cars for sale section for 11,000 plus this stout build. It would be great to bring the two together for a match
The picture shown does not look like a BHJ Balancer on this motor? was it removed?
I decided to part motor.
Short block has been SOLD.
Will list heads, intake, TB, etc...later on a separate post..
All PMs answered.
All PMs answered.
I'd be interested in the valve covers if you still have them, let me know thanks
All PMs answered.
Hi there I was interested in your motor for sale. Sold I guess?
