Complete stage2 heads & drysump system
49-blues
I have a complete set of stage2 aluminum heads with 2.08 /1.650" valves,springs,keepers,T&D roller rockers,valve covers,pushrods,high rev lifters & a complete drysump system with reservoir,remote oil cooler,braided lines,pump,brackets,moroso oil accessories,mandrel drive that i need to sell to finish my stage2 street motor,free edelbrock stage2 intake comes with the heads-looking for $1300. for the heads& $1000. for the drysump set-if purchased together- i ll let it all go for $2200. shipped.
Heads,valves,springs, roller rockers, & valve covers complete for $1000.
Do you know the cfm base and max on the intake and exhaust and/or the chamber CCs and/or the runner CCs and/or if they can be used on the TA Aluminum Block lastly and/or if they are 8 or 14 bolt? Thanks, shoot me a PM with whatever info you have or can find. Thanks
The intake valves are 2.08" & the exhausts are 1.65", they #0031 aluminum 14 bolt stage 2 heads-not sure of the cfms yet-im thinking of having them all reassembled , they came off my #0016 off center block-it was a $25K Werner built motor 274" with a 4.00" bore., if i have to pay to assemble them the price will go up accordingly-these heads will be ready to bolt on & run.
i'm sure this is quite obvious but do stage 2 heads have to be used on a stage 2 block? Thanks
They "could" work on a stock block but it would have to be a 4" bore block.
But that would be severe over-kill.
They would work best on a SII block or 4" bore TA block. Something that could take advantage of the tremendous flow capabilities.
2 complete aluminum #0031 stage 2 heads -with T&D roller rockers ,lifters, pushrods, valves, springs, retainers and valve covers, and 2 stage2 carb intakes-1 bms and 1 edelbrock for $1200. shipped in the USA.
