1NASTYGN
I am pulling this motor to freshen as recommended and am not going to keep my car a V6. I have a few options to install so its either LSA or single turbo LS. I can perform compression tests or whatever is asked once I pull. I can take videos of the car running etc....
Looking to sell my fully built and balanced motor with engine harness built for a FASTXFI set up, pan to plenum. Less than 3000 miles in 8 years, car sits in garage, gets an oil change every other month regardless of use, never ran hotter than 193 degrees. Complete with FASTXFI with edash , TCI TCU, custom 4l80e torque converter and Precision 6870cea. $18k or whatever we can negotiate. I might sell everything separately also.
Stoker 274ci RJC Girdle: ARP head studs. 4140 Eagle 3.400 crank, Molnar rods, and JE 9:1 pistons. 224/224 Custom Grind Cam. Ported TA performance SE heads with 1.60 rockers, Champion intake, and 72mm throttlebody. GN1 4 bolt headers, 46MM WG, 160lb injectors, Poly mounts, Executive RJC pullies polished TR6 with smart coil conversion.
