SignUp Now!Which is best an engine with high compression or an engine with low compression?
Increasing static CR vs boost pressure - ModularFords.com
Read this thread, it will answer your questions.
So what is the general consensus for our motors for a 9-10 sec car? Is it more boost/less compression or less boost/more compression that will make the most power with a broader power band?
Some good math there but they completely leave out the cam profile and what happens when both valves are open. It changes the picture a lot. After reading that article some may be convinced to drop the CR to 6:1 and run 50-55psi . When the engine is built around a higher CR and high boost with the proper fuel it will make more power everywhere in the operating range. Especially when out of boost or low boost like spooling. This can change the converter requirement down low making it easier to get a good coupling % up top. If you plan on running 93 octane there is little reason to increase CR.
So, the real question should be the affect of dynamic compression on a turbo buick VS static compression right?
A.j.
Octane isn't a problem i run 114 with my old combo.
You can still detonate on 114
Good post Bison
a given HP at 7000 will have a lower bmep than the same hp at 5000
So basically what you are saying is the larger the cam (higher rpm band) the more compression you can get away with.
Seems like you still have trade-offs. Run the larger cam and you lose some low end anyway even though you can boost compression. Delicate balance there between too much and too little cam (and compression) I would think.
