turbotony1
- Mar 3, 2011
My 109 block is now in for machining. I would love to make it into the low 10's with my combo. The build will be...
Billet Main Caps (center two or maybe the front cap too)
BHJ Balancer
Full Throttle Stroker Kit
Champion Iron Heads with Cometics and Champion Ported Intake, Hemco Upper Plenum
Roller Cam with Morel Lifters and TD Roller Rockers
TA High Volume Oil Pump
One of our TB Vendor's Headers T.B.D.
I'm looking into a 66-68mm Precision Billet Turbo
I'll be running either E-85 or Race Gas
I would like to hear what you guys would recommend as far as compression ratio. I've heard lots of talk about keeping the engine close to stock (8 to 1 or 8.25 to 1). However, it seems that lately lots of people are going up to 9 and 9.25 to 1. I would like to know the thinking behind the two different theories. It seems to me that the people who are for 8 to 1 say it will allow you to safely run more boost, and higher boost levels equals more power. On the other hand, it seem like the guys recommending higher compression seem to think the advantage is more low end torque and very little difference in safe boost.
Any comments are appreciated,
Anthony
BHJ Balancer
Anthony
