S
Stephen Soulsby
Guest
I performed a compression test on my car tonight to check for anything out of whack, but I'm not sure what is normal. My highest reading was in #6 with 150 and the lowest was in #5 with 125. If my math is right that is 16.6% difference. I did the test with the motor hot (burned skin to prove it) and all plugs removed.
My symptoms still are:
Low vacuum (12@idle, 10 in gear)
Erratic idle
Stumbling off idle (almost with rythem like a faulty cylinder)
Way too much detonation (only when warmed up)
Erratic misfire while driving (very noticable with TCC engaged)
Slow cranking most times, sometimes normal. Bat. and alt. good
How is my compression? I'm not confident in doing a cylinder balance test not knowing of any possible damaging effects it may have on the coil and module.
Erratic idle
