How do the other plugs look? If just #6 is oily then check if the intake valve stem seal is riding the stem (BTDT). If that isn't it pressurize the plenum and check if air is blowing out the breather. That is a sign of a bad intake gasket or cracked intake.
RemoveBeforeFlight
All the other plugs are in pristine condition. I've also taken the pcv out of the equation by unplugging it from the plenum and it still smokes. I went as far as to remove the plenum to check to see if there is oil and its also clean.
How do I go by pressurizing the plenum??
