Leak down test would be nice to do as well, thought I start with a compression test as I have the tool for doing this ... well I thought I could use it until I warmed up the engine, burnt my self removing all the plugs ... disconnected the cam sensor ... and the threaded part on the compression tool is to short to reach into our heads
So back to square one ... what do you guys use to check compression, do you use a long reach 14mm adapter like the one supplied in this kit
http://www.actron.com/product_detail.php?pid=16170 ?
Will go shopping tomorrow but might have to order a kit somewhere, anyway let me know what you all use that works
