Compressor housings and diffusers
turbojoe1
I see a lot of options out there. Can someone shed some light on the differences between the same turbos except the housings, in a matter of flow and efficiency?
Say a 5858 with S cover vs the same 5858 with an E cover.
The various 58mm wheels all perform well in a housing with a 5" diffuser. There would be little gain with more diffuser. The inlet size doesn't matter much. The housing could be a limitation in applications where high mass flow is required. You wouldn't want any of the common 67mm wheels with a 5" diffuser if you were looking to run them to their potential. The stock compressor housing is a variant of t04b and t3 and has a very small diffuser and performs lousy with larger compressor wheels. Even a 58mm compressor is limited in it.
Here are 4 variations. The H, t04s04, "s", and e
Precision h top and Holset below. They are identical
Diffuser in Holset cover
H and t04s04. Notice 3" inlet on the t04s04. Don't be deceived. It's a bad ass cover and works very well with any compressor in the 62-72mm inducer size even if the wheel has a very large exducer.
T04s04 diffuser. 5 5/8. Supports a lot of mass flow. It's larger than the h
S top and e bottom
Both have 5" diffusers
T76. Same as t04s04 except 4" inlet. Large diffuser and nozzle area. Excellent for large wheels while still retaining t4 components.
Thank you very much Bison, very helpful information, and pictures. I'm sure in the near future I will be obtaining a turbo from you of your recommendation.
Thanks Joe
Sent from my iPhone using Turbo Buick
