computer help
shawnz
When i run AVG and end up with 5 viruses it says 0 files healed .What do i do then just leave them in the vault as im not sure thanks John
Most likely you can clear the vault... Im just guessing here but are these things related to Java?
Staying in the vault would most likely be ok also. There might be an auto purge setting already in place (AVG not on the computer Im using).
Anywho, if you tell us what it found, better advice may be given.
