EightSecV6
MDBL
- Jul 18, 2001
Originally posted by KLHAMMETT
Also make sure that the turbo drain is setup correcltly,If it is not oil WILL back into the turbo and force it self out the ex side
Definatelty check that too!
Just so were on the same page - This motor has 159 miles on it. This Rotella oil is not synthetic and I believe without seals and the oil building up in the valve covers to the point the oil is up to or covering the rockers- oil is going to find or be sucked down the valve stem in addition to have a windage probem. Just my opinion. LarryOriginally posted by sixgun86gn
#1 never break in a new motor on synthetic oil...period
#2 it takes more than 15-20 miles to seat rings anyways
#3 oil to the rockers or lifters will not make any difference on if the motor burns oil or not.
Check the turbo and put some conventional oil in the motor,may need to flush out the synthetic ,and drive it at least a few hundred miles to get the rings seated.I usually wait until a motor has around 1000 miles on it before I put any kind of synthetic oil in it.I am no expert,but this has always worked for me
I also used gapless rings and they took a few hundred miles to seal good as well.The statement about them pulling oil from underneath is not true.
Larry said:Well, things got alot worse . . . I need a break from this thing. Wish I had better news - I could use it. Larry
GARY HARVEY said:Non Detergent single weight for breakin and analized for problems. Most any of your local diesel operations can put you in touch with someone that does analysis.
Why are you pooling oil in the rocker covers? Are the return openings restrictive and is the oil piling up on both sides?
I'd like to hear you getting a little more help from the TA group with your/their
teething situations in light of the problems you have run into.
Hangin there,
Gary
Big Stu said:. . .I lied about not saying anything else...![]()
BAGN said:I know what you mean. Its like a sickness. Put the keyboard down & slowly back away![]()
Hey, Thanks- but that is not necessary. Im not looking to get anyone ticked off here. Im just looking to get this car running. I thought about it alot when I placed the order three years ago. As an independent insurance adjuster,the cost was over my head, but- I made that decision when I flew out there to meet him and see his operation- its very impressive. The motor is a good piece and their were no guarantees, mine just needs a little massaging. As a business man- he just runs his differently than I do. I can't and would not try to change that. Thanks for taking your time here. LarryEightSecV6 said:Larry,
If you dont mind, have Mike at T/A call me, regarding this stuff.
