Confusing pl log
psycho6cyl
Ponies Are For Lil Girls
Ever since i installed pl w sm update I've been seeing knock. finally got a log. So it seems to be a ciuple of problems. I need to reconfigure my fuel reading. its way off. 2ndly I have a 2bar map sensor but yet on pl it spiked to 27# w s little kr. but my boost guage has not moved past 15bls max.. im at a loss
You need to configure the PL software. Go to "configure and download" on the left side tab, and select applicable parameters....ie 2-bar map, which chip you have...etc. When you select the 2-bar you will see that you only made about 10lbs of boost. It's a little worrysome you got some knock. I would probably verify FP is rising 1:1. Otherwise it could be false knock.
Thx rafs. I thought I switched 3 bar to 2 bar but will do that now. Im not.looking at log but I.remember 02s being around 800s.. love the pl tbough. All.I wanna do now is tune tune tune.:D
