I'm finally getting ready to hook up the FAST to my car and need a little help with ignition wiring. The FAST I have is a sequential unit, the ignition box is an MSD 7AL-2. I have the crank and cam triggers wired up but need to know which wire from the FAST to connect to the white wire on the 7AL-2. Reading the FAST manual shows two different connections for GM HEI setups (closest thing I could find for my setup) but it does not discern where the wires go to the GM wiring. It only show the A B C and D pins and says hook them to GM pins A B C and D. Looking at the FAST wiring diagram shows the four pins A-EST, B-Crank Refence, C-Bypass, D-Distributor Reference .... which one of these needs to be connected to the white (trigger) wire on the MSD 7AL-2?
