109 engine stock crank, recond. rods.,TRW FORGED PISTONS(30 OVER)
engine ran fine before it was gone thru, good oil pressure and no noises(block was frozen and cracked) and the crank looked perfect. i bought new rod and main bearings and had the rods recondtioned with arp bolts.
side clearence is good. but you can take the cap and try to twist the rod on the journal and there is a little bit of rotation as you can see the piston move a little bit in a cicular way.
is this normal with these engines?
It has good side clearence and no play when you try to push and pull the cap with your fingers.
you can twist the cap a little.
