8
84camaro
Guest
Hi All,
I hope that there is someone out there who can help me. I am putting a 3.8 Turbo Trans Am engine in a 84 Camaro Berlinetta. I am just wondering what I should do for front springs? I pulled the springs out that were in it, and the dealer said that they where from a 91 camaro with a 3.1, but the car had a 4-cylinder engine in it, and was bottoming out with almost every bump. Has anyone put a 3.8 into a Berlinetta? If you did can you tell me what springs you used? From what I have been able to read, a TTA orginally came with a BXX spring. Could I put this spring into a Berlinetta without creating any other problems? Although, from what I hear the BXX springs are no longer available. If I used a spring from a V8 Berlinetta how much would I have to cut off? And is there any springs that I can use that I will not need to cut?
Also, does anyone know what springs an 84 Camaro Berlinetta came with, and what the height of the spring is compared to that of the TTA.
Any help in this matter would be greatly apprecated!
Thanks!
Thanks!
