converter choice
SIXBANGR
mean old man
I have a th400 with a PTC 3800 stall. i am going back to my 200r4. I have a Pats 3500 stall l/u i was using. Should i go back to the Pat's or have the PTC changed to work with the 200? Car has a GT70 p trim. 83's, heads etc. Won't be racing much but don't go on vacation with it either.
The PTC`s can be used with a 2004R.
Their non lockers seem to be working very well.
I don`t think with a high powered car I would use that old converter.
Send it back to PTC and they can cut it open and switch stators. If it works well why change it? It will be the cheapest route.
We could change the stator for the 200r and tighten it up a bit.
Dusty
I e- mailed you earlier today on this. I am happy with the stall, unless you think i should lower it.
If the stall works like you like it, we'll just change the splines to work with the 200r and send it back.
