turbojimmy
Supporting Member
- May 26, 2001
I have a Vigilante 5-disc converter in my car. It seems the car has slowed down since I ditched my 9x11 and replaced it with this converter. The 9x11 was not locking up anymore, but even so it seemed more efficient at the top end.
The Vigilante seems okay at launch - not too loose. Seems to be stalling around 3200-3500 RPM as it should be. By the time I get to the end of the track I'm at 5700 RPM at only 115 MPH (3rd gear) with the converter LOCKED. According to my calculations, with the converter locked at 5700 RPM I should be at 138 MPH.
In the graph below you can see a small dip in RPM when the converter 'locks' at around the 8:19 mark (the numbers on the bottom are seconds). I e-mailed Vigilante and they said it's not likely the converter but a pressure loss in the trans that the 2004-Rs are 'famous' for.
http://turbojimmy.4t.com/062207-1_log.htm
When not locked, is the 5700 RPM @ 115 MPH 'normal' or should the converter be tightened up anyway? Should I just go with a non-LU and be done with it? I hate to do that after investing so much in the Vigilante but I'm tired of wrestling with this problem year after year.
Jim
Jim
