Converter
Turbo z28
Looking at a PTC converter from Fullthrottle speed, would this be the same converter if i got it from Dusty Bradford?
Same company, yes. Same converter, depends on who specs it for your combo. HTH
If you call Dusty he tweeks it specifically for your car and goals. I would drop him a PM and give him a call.
X2 I called Dusty and he gathered my engine specs and goal for the car and a week later I had my converter. Real pleasure to deal with...and fast!
Everything is built to the order. If I had time to get caught up I do try to keep some on the shelf but build time is rarely over 3-4 days.
X2. We got my Dad's tc in a week or less and picked up .4 first day out.
How do you know if you need more stall?
Welcome to the board...BTW, fill out our signature so when you start asking questions other members can see what parts you are working with.
A good indication would be if you have a larger turbo and it has alot of lag. Picking the right converter also depends a lot on your goals for the car. It may need to be looser down low to spool the turbo but also needs to couple at the big end. In our cars, the converter is a very important piece in ones combo...
Oops, I somehow didn't see your post when I posted some info. I didn't mean to echo you. :confused::D
