WE4
TBcom Admin /Prayers NYFD/NYPD
- May 24, 2001
hrmmm I disagree
Turbo dave quote
REMAN D5
unlocked in the middle of 2nd gear yielded 55%
unlocked in 3rd at 80mph yielded 85%
unlocked in 3rd at 90mph yielded 90%
unlocked in 3rd at 100mph yielded 94%
locked in 3rd at 80mph yielded 93% ***
locked in 3rd at 90mph yielded 98% ***
locked in 3rd at 100mph yielded 100%
Now for the VIGILANTE. (These readings are at the end of it's second season of racing) (Always locked at WOT and about 80mph) (a couple seconds after the 2-3 shift)
unlocked in the middle of 2nd gear yielded 50%
locked in 3rd at 85mph yielded 97.3% ***
locked in 3rd at 95mph yielded 97.6% ***
locked in 3rd at 105mph yielded 97.7% ***
(the 10ths of percent differences could be attributed to measurement errors).
I did find some early Vigilante runs and it was rock solid at 99.7-100% through the above 3 parameters
My reply.... ( due to Mr Computer genius here, I have more trouble with these quotes and crap!!))
( I put *** next to what I found odd)
The first thing that caught my eye was,the ***"s I dont care what RPM and Gear and speed your at, locked, the converter should be 100%. If it is not, trans is slipping. PERIOD! With that in mind how much percentage of slip does a manual trans have? With the clutch out it would be zero ? correct? Well a locked converter should be the same. AND not to take sides but if the trans is in fourth locked it will show over one hundred percent because the gear ratio will show more out than in.OD is about 30% , over. Now if I got this right, with the D-5, you say at WOT in 2nd gear it has 45% slip? With either converter I find this not possible. No way. It has to be more effiecent than that. With your Vigilante I might agree but with a D5 stall would have to be 4000-5000 to get that number. It would be REAL REAL ugly..Heat would be through the roof! And at load it best be a whole lot better than that (45%) or car is gonna be real high stall or rpm'ing big time and car not moving along well
REMEMBER!!!
A trans puts out only what is put in. RPM is the factor. Speed has nothing to do with INPUT speed. Once converter is locked, 100% has to be achieved unless trans is slipping or converter is slipping. Think about it. .The D-5 shows exactly how effiecent they are throughout the power band. The 9X11 converter is alot the same in this aspect. EVERY single Vigilante converter I have ever seen was always too loose for whatever application it has been in. ALWAYS loose. great for all out drag racing but sucks for everyday driving.
Just my thoughts...
Prove me wrong Dave....
What scares me is you just might
BTW ..... How are you out in the middle these days? I will always resent you for leaving this God foresakken state and NOT taking me with you!!!! You are an evil, evil person for this.....
ROFLMAO
Bruce
WE4
And..... will you two knock it off... both of you.... LOLOLOLOL
Turbo dave quote
REMAN D5
REMEMBER!!!
Just my thoughts...
Bruce
WE4
