Convo pro rims, slicks, Nitto DRs, front lowering springs and arms
murphster
Just about finished doing my front suspension and just took most of this off my T Type. I will split shipping on all the items. I estimate about $30-$40 shipping on each item through USPS.
I have two sets of springs. The first are SPC lowering springs from Savitsky Classic & Custom. These lower the car about an inch. I had these on my car the last couple years. $75
The second set of springs are Moog 8306. These were on the car for mock up purposes only. I needed a set with square end bottoms for my new control arms so I didn't use them. These should lower a car about 2". They are a lower rate spring better suited for drag racing. They are spec'd for older Mustang V6 non AC. $40.
The control arms are front lower stock arms with Howe tall ball joints from Savitsky installed. The ball joints lower the car about 3/4". The shock mount has been opened up some for adj shocks. $100.
I have 3 sets of 15x8.5 5" backspace rear and a set of 15x7 3-3/8" backspace front Convo Pros. All rims in excellent shape and center caps included. The fronts fit fine on any car, the rears require a frame notch or a small spacer. $250 for each set, $300 shipped. I'll do $1100 shipped for all 8 rims.
I have a set of 215/65/15 BFG Radial TAs that were on my front wheels. Lots of life left. $50. SOLD
I also have a set of barely used 28x10.5 x15 stiff sidewall MT ET slicks. $200 SOLD
Finally, a set of 275/60/15 Nittos 555R DRs with little use. $150 SOLD
I will take some pics of rims and tires soon, but included a pic with them on the car with the SPC springs and control arms up front.
Here are a couple pics of the slicks. Hardly used, probably a dozen passes.
Tires are all gone. I'll do a package deal for all the rims if someones interested. Great wheels.
How much for front and rear convos with caps shipped to 70431. Also do you take paypal.
Sale pending on front rims. Besides the front rims and tires, everything else is still available. I'll do $300 shipped for each pair of rims. Rims include center caps and metal valve stems.
Your quote was
I have 3 sets of 15x8.5 5" backspace rear and a set of 15x7 3-3/8" backspace front Convo Pros. All rims in excellent shape and center caps included. The fronts fit fine on any car, the rears require a frame notch or a small spacer. $250 for each set.
Then
$250 a set or $300 a pair shipped? I'm confused.
$300 shipped for each pair of rims. I'd take $250 local for someone picking them up. I didn't mention shipping in the original post.
Front rims are still available. I updated first post. I'll do $1100 shipped for all 8 wheels. Offers considered for suspension stuff.
Front rims are sold, everything else still available. I'll do $270 shipped for each pair of rear rims.
Are all the springs for G Ns , Set 2 mentions Mustangs? Are they street friendly?
I'm interested in a pair of 15x8.5 with 5" bs wheels. I think they will fit my TTA. Can you hold a pair for me till I find out if they will fit? If they will work, I will buy them.
The SPC springs were bought from Savitske Classic & Custom for my Turbobuick. A full set goes for $289 for front and rear but these are just the fronts. They will fit all Buicks fine and handle great.
The Moog set lists for a Mustang but they fit my stock control arm fine. They are similar to a Moroso trick spring but not quite as long so they should be a little better than those for street driving. Combined with some cheap spring spacers from Pep Boys you can tweak the ride height. I would have used these for the track but my new lower control arms needed a square end spring.
I can't promise if someone offers to buy all 3 pair, but its doubtful they will sell that quick. I did just list them on some other sites though. I did a quick search and it looks like they should fit fine. I think you only want 4" or less sticking past midline so they don't stick out past the fender. With the 5" backspace you only have 3.5" past center to the outside. If it was a 10" rim you'd want around 6" backspace.
I think it will be too close. Im running the stock front (4.75 bs) wheels on the rear and they are even with the lip. I need a 29" tall tire to fit inside the wheel well and I dont think it will work with this rim size. Sucks.
