Coolant in oil
Thanks everyone for you help and advice!
Took the voltage booster off and now seems much easier to tune with the alky. Made a few runs at 22 lb boost and alky on 4 with wide band showing 10.6 in 3rd wot with no kr
Found my notes. Per this engine builder inlet temps ~52° meth will not flash.
And make sure you dont hit the fuel cut rev limiter while spraying meth
most factory rev limiters are a fuel cut to limit rpm.i dont know if any of the chips from the vendors on here are modded for spark cut instead. if you are spraying meth when you hit the limiter the engine wont quit it will just go very lean very fast and thats when the damage happens.hence the bob bailey 2 step spark cut limiter to cut spark instead
