Cooling and Exhaust
Wizard
2 questions!
1. Gets hot but doesnt boil over. It takes 35 minutes to reach 220+ Deg. Gradually increases. I drove it around town here in OK, outside temp 88F. Water pump is new, big rad, 160T. The flow is fine through the radiator, with the cap off. I have heard bubbles in the rad would show a blown head. I have never seen this before. Are the bubbles suppose to be huge or just have bubbles present? I have little tiny bubbles that is pretty constant.
2. Does anybody have the Kenny Dutwieller exhaust on there hotair? Mine was a pain to install and the downpipe rubs the frame giving false knock on direct scan.
Thanks in advance for any help provided.
I think that the bubbles in the rad would indicate a blown head gaskit, poissibly worse. Do you see any oil in the water? Rember, water in the oil means cracked head. Oil in the water means cracked block.
