Jackie grabos
- Feb 2, 2011
hello, i just installed the gn1 performance front intercooler dual spal fan set up. it is plug and play. have everything installed and will not come on. my previous fan was direct wired and ran as long as car was on. when i disconnected the positve cable i heard a click from the engine. next the fan kicked on for about 2 seconds and stopped. it happened when was disconnecting and the screw touched the outside edge of the terminal. when i screw it back in it will not come on. if i start the car and disconnect again i hear the click from the engine and fan comes on for 2 seconds. have checked the fuses. could this be caused by a bad fan delay relay? if so this would explain the hotwired fan. also where is the fan delay relay located if this is the problem. thanks-jon
