Well after a fun weekend of racing I went to change my oil and found a few copper like flakes on my magnetic drain plug. This concerned me so I cut apart my filter and found a not so pleasant surprise. No actual flakes like on the drain plug, but the oil in the filter looked like a metallic paint. Filter element was coated with it as well. This means excessive bearing wear (crank, rod, cam) correct? Looks like I have a new winter project.
Any ideas as to what caused this? I have always had VERY good oil pressure. This particular weekend I was running 24-25 psi boost and winding it out to 6100 rpm. The engine is girdled, but I am using stock crank and rods.
