 - May 27, 2001
If you have the stock chip, replace it with anything else modern. The start up on the stock chip was terrible.
SignUp Now!25 is ok for warm low idle in park A/C off.Thank you. I didn't know the IAC count was related to engine starting.
With AC off, it's below 25, but with AC on, it exceeds 30. In Japan's climate, we use AC most of the year, so should I adjust it to below 25 with AC on?
Thank you.If you have the stock chip, replace it with anything else modern. The start up on the stock chip was terrible.
Thank you, Mr,GNVYUS 1.Hey Masashi, welcome to the board, you gotta be one of the few guys with a GN in Japan, sweet.
My guess after reading his post was, from all the 38 years of driving, the TB blade screw is a tad out from bouncing.
Or maybe the stock chip commanded a low idle rpm, not sure anymore, anyone remember???
Before you turn in the screw on the throttle body, wait to hear some other replies.
If you do turn IN the screw to open the TB blade a tad, you'll then have to adjust the TPS and most likely the IAC/ISC will drop a tad. The OEM chip might command 700rpm, I can't recall factory idle rpm.
Thank you. I understand. First, I will see how the IAC works in its current state.25 is ok for warm low idle in park A/C off.
TurboTweak chips are very popular and an easy swap. Here's the page. You can get injectors and a chip all at once if you want.Thank you.
Can you recommend any chip?
Thank you for your quick response. I was able to check the product page!TurboTweak chips are very popular and an easy swap. Here's the page. You can get injectors and a chip all at once if you want.
