correct wheel size
Raist103
just need a yes or no, i did a search and everyone always comes in and says i have all these different sizes and they fit, i just need to know if these fit or will they rub.
15 x 8 WITH 4 1/2 BACKSPACING, 5 x 4.5/4.75
with a 275-50-15 rear tire. i run 275-50-15s now on stock wheels and they fit fine.
if you dont know but DO know the stock gn rim bs please do tell.
thanks
don
15x7 or 15x8 3.5 backspace w/alum drums will work w/275-50-15. more back spacing if alum drums not used,like 4 to 4.5
I run a 15 x 8 with 3.5 bs and a 295 50 15 tire. Fit is fine although I think that size tire is a little short. I'll be switching to a 275 60 15, which should be in the neighborhood of around 28 inches tall.
i can get a good deal on these
2 @ 15 x 8 and 2@ 15 x 3 1/2 for a 5 x 4.5/4.75 bolt pattern with a 3.5 back space
but wanted to make sure they would fit before i got them. the ones in the first post are not new and are a ok deal but these are a much better deal and are new.
so i checked tire size and a 295-50-15 is a taller tire and you get no rubbing? scott.
suicide six are alm drums wider or shorter? why do you say a 4 or 4 1/2 would be better without the alm drums? stick out to far or in too much?
For a "drag" look, I think a 275 60 15 is a better look at around 28" tall. The 295 50 15 is only around 26" tall. I'm gonna put my 295's back on in a day or two, if you would like I could snap a pic or two to show the stance.
