SignUp Now!no i was putting in an aluminum core support in that picso you have to remove the header panel to install ?
Yes it came with the tabs. I'm not sure but I do not think it's necessary to remove the bumper to install it but I guess it makes it easier. The bumper is off the car in the pictures because I was having both shaved and repainted.did it come with those mounting tabs.?and do you have to take the bumper of to install
Same hereThe Cotton's FMIC in my car has a single tab on the bottom. Goes to the hole between the two tab version.
There are two studs on the top to go through existing holes, with a washer and nut to retain.
I have R&R'd the intercooler and it was easy. Open hood remove the two nuts. Jack up onto jack stands and loosen the hose clamps. Push hoses back out of the way.
Remove the bolt on the tab and lower the IC out. To install, it can be finicky getting the two studs through the upper holes. But once there it goes quickly.
RemoveBeforeFlight
what did you replace it with?
