Hello everyone. Recently I did a lot to the upper half of my engine. I powder-coated the valve covers, turbo shield, plenum, and the up-pipe. I put new valve springs, new 42.5lb injectors, new gaskets throughout (except intake and heads) and a TT chip. The car runs and drives a lot better. But now here is my dilemma. According to my boost gauge, the boost is bouncing back and forth between 10-13lbs. I was told that it is most likely a vacuum leak. So maybe my car is not running as well as it should be? A year prior, I won a Cotton's billet aluminum vacuum block with the push-lock connectors and plastic line. I want to install this, but it seems I need to buy some fittings so that I can adapt my mane items (PCV, MAP Sensor, Boost gauge, AFPR, and the EGR and Charcoal canister lines). I want to use barb fittings for the charcoal, egr, and PCV. I also want to adapt my MAP Sensor, and AFPR to the push lock fittings. I just have a couple questions so that I can order everything right the first time. I want to get this squared away so I can put on my Razor Kit
-What is the size of the fitting on the MAP sensor?
-Can I drill the AFPR and tap it for the push-lock fitting? The AFPR I have has an integral fitting on the top half (meaning it is part of the actual top part). Can I cut that off and drill it out?
-The PCV will be a 3/8 90* barb, but what about the EGR and Charcoal? What size barb should I use for these?
-The big question... Do any of you fellow members know where I can order these fittings or where I can buy them? Local Autozone, and Advanced do not have what I am looking for.
Here is some before and after:
Before
After
Picture of the AFPR:
Picture of the vac block (powder-coated satin black to match stock one)
Thank you,
Zack
Before
After
Thank you,
Zack
