could I use 409 Alloy Stainless Steel = radiator pipe
XxDarkSidexX
Banned
I found another good deal on some 409 Alloy Stainless Steel pipe. Its 1 1/10 inch outside diameter or 28mm. It has a wall thickness of 0.7mm. Would this work for some custom Radiator piping? Thanks in advance!
darkside
I'm sure it will work great. I went to HD and bought 1 1/4 polished sink drain pipe to use for my upper radiator pipe:eek: . (around $5 :D )
nice dude! thats exactly my lil game plan. should work for the lower to right?
so where did you get the hose? Hope its as inexpensive as the sink pipe :). I found a few feet of 409 polished for like 10$ hehehe.
The pipe is from Homedepot, the hose was already on the GN, it wasn't very old and I just cut the angles out that I needed. Even found the hose clamps at homedepot. I think that the lower hose is 1.5", but not sure? Good find on that stainless pipe! Much better than chrome plated copper....:o
i should be able to apply some 1800 temp paint on the pipe right, make it look black?
what agood idea usein the stocker hose, but mine has gotta go its pretty old. Im sure I can find a inexpensive hose set though no biggie.
