groumoutis
- May 1, 2009
I posted this in the general tech area and got nothing so maybe I will get the answers from you transmission guru's.
The car runs great under normal driving but when I give it a decent amount of go faster pedal the car hesitates at the beginning of each gear. It hesitates for about a second and the accelerates like normal. It doesn't do it every time and when it does it isn't alway the same amount of hesitation. The rpm's drop and do not flare. Could this be a shift solenoid? TV cable? I am not a transmission guy at all. I did change the tcc solenoid, filter and oil this spring. I went on the power tour and it ran perfect and a day or so after getting back this problem arises. Any help would be greatly appreciated!
