couple ac questions
gsbuick65
1st my car misses when I have the ac on, i thought maybe it was a injector or wire, so I stopped to get some injection cleaner. and when I left the auto parts store I had the ac off and noticed no miss, turned it on and there it was.
2nd is the ac compressor suppose to be about 3/4 inch from the up pipe? seams like it will burn out the seals where the hose connects to the compressor.
Answer to question 2 is in the PIC. Brad
my belt must be longer cause the bolt that holds the hose end to the compressor is right beside that flange, guess ill put a shorter belt on it and wrap it with header wrap, and freon must be low cause its not blowing cold, maybe the compressor is kicking on and off.
BTW-time to get some new tires, I threw the tread off one of my rears, now gotta clean rubber off the quarter panel. :mad:
