87we4turbot
- Jun 24, 2002
ok got a couple questions.......i am starting to clean up my dad's 87 Turbo T. She has 53000 original miles but has been sitting outside she is now protected inside but needs some woek. One of the first things is brake issues. The last few times i have driven it the brakes have acted strange. if i try a panic stop and hit the pedal it doesn't want to move for a second then it releases and the pedal pushes in and the car stops. If i come to a slow roll and put my foot on the brake a little at first it stops as normal....not sure what is going on. Today i looked at it to see if it was low on fluid but seemed ok. With the key to the on position when i push the brake in i can hear whasounds like a relay click and a vacuum leak underhood by the brake booster. Any ideas to start with? The other question is can i still get a headliner board for this car. Ours is pretty bad and wanted to see if it could just be replaced. Also the metal trim piece under the windhield wipers. Can it be sanded and repainted and if so what color? Ours is starting to rust on the corner and i wanted to clean it up. Sorry for such a long post i am sure i will be here more often asking questions and appreciate any help. Oh and here are some obligatory pics
