Coys Wheels
hemi8
Goin Sideways
Couldn't be more pleased, ordered 17 x 8 fronts, 18 x 9.5 rear, showed up 2 weeks after ordering, C5 polished, they are beautiful. For the price and quality I don't see how they can be beat. I am very satisfied. I'll post a pic after I get them mounted.
Mike
hello; I went quickly to there E-bay store and are those wheels like $700.00 a pc.?
IBBY
5" rear but I have .2" spacers so it will be 4.8, 4.5 for the front. I have 12in SSBC brakes up front with ATS spindles and the wheels clear them with no problem. The calipers stick out past the rotor face the exact same as a C-5 corvette calipers so if you have those these will fit. Tires are 275/40/18 rear and 245/40/17 front, Baer brakes in the rear.
Mike
Those are the wheels I like! Nice! Can't wait to see them mounted.
Had the tires installed on Friday, drove it this weekend and couldn't be more pleased. I wound up not using the spacers in the rear, with the 5" backspacing they fit perfectly, I can fit my fingers between the tire/wheel and the frame, no rubbing at all. The fronts do not rub anywhere, I belive this is the perfect combo with the particular brake/suspension set-up I have. I dropped the rear by installing Global West springs to compliment the drop in the front from the ATS spindles. The wheels come with flush-mounted valve stems for guys with huge brakes, mine would have worked fine with 7/8" tall regular valve stems but the tire installer was unprepared so I went with what I had.
Mike
hello; I can't make out the tire? What tire did you go with and do they do a tire rim combo deal?
IBBY
Sumitomo HTR Z, I do not know if Coys offers tire/wheel packages.
Mike
Looks good, glad you had better luck than I did years ago with them. :rolleyes:
