Ok, not sure if all you guys have seen my early posts or not. But, I have been struggling to find boost, since last fall!! I then found out I blew both my head gaskets. I was burning antifreeze through the exhaust. So, I got the heads off and took them to a shop and the guys said that if the heads had cracks they would be on the outside of the heads since the antifreeze was burning through the exhaust.
So they didnt magna flux 'em and I didnt know the difference, I mean these guys are the pros'
I now know I should have gotten them magna fluxed, NO MATTER WHAT!!!
I now got my car back together with new headgaskets and non-magna-fluxed heads and I have the same damn problem......no exhaust leaks, puck sealing fine....wastegate rod as short as it goes.......and only 10# of boost. And a very small trace of white smoke. Reminds me of my car a few weeks before it started to just pour white smoke like a chimney. So, I am leaning towards cracked head?? The car also stubbles and jolts, so to say, when I step on it and any speed. And from a stop it hesatates and then goes......like it wants to die.
I havent had time yet to do any pressure checks on it........as I am in the middle of changing heads on another vehicle
Would a crack in the head cause this lost of boost........were would the boost go into the coolant?? Can I do a pressure test on the cyclinders when they are cold.........as the passenger side is a pain to get to......spark plugs.
Thanks for any advice, as I am so sick of this........I am almost 100% sure it is a bad head? Thanks, Nick
