Crank Sensor bolts??
Having trouble figuring out which bolts and how the crank sensor bolted to the cover and CANNOT find a clear picture anywhere?!
Can someone help? Maybe with a picture of yours? Thanks!
The bottom bolt is the longer of the two 'special bolts' with the nut in the middle that the intercooler bracket bolts too. The top is a normal bolt that's got extra length on it so it can go through the bracket, cover, gasket and block threads.
This isn't exact but it will show you the approx protrusion you should expect...
