Crank trigger timing?
forzfed
The crank trigger has to be installed on my BHJ balancer. I know there has been discussion before on this. But what is the excepted method. Also, since I'm not using a timing chain tensioner would you clock it differently? I remember this being posted.....
Are you asking where the signal should come in? If so, it depends on ignition type and what ecu.
Yes, I'm using the stock ecm. Where should the "0" degree timing mark be located? BHJ says to install it on the leading edge of the key weight groove. This works out to approx. 2' on the balancer, but some guy's are saying around 3.5'.
Since I'm not using a timing chain tensioner should I add a little more? What would you suggest, Cal?
