May 18, 2009 #1 A asto-t Member Joined Dec 9, 2006 Messages 694 When is needed to go with a steel crank and pistons over stock crank? I plan on rebuilding my engine and adding te-49 turbo
May 18, 2009 #2 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 asto-t said: When is needed to go with a steel crank and pistons over stock crank? I plan on rebuilding my engine and adding te-49 turbo Click to expand... Unless your going to be making some serious horsepower you don't need a steel crank. Using a te-49 turbo confirms you don't need a steel crank.
