Kid Turbine
- Jul 17, 2007
Well here is what I have new engine install but will not crank but trys to thought. Engine on 0 TDC on compression stroke with #1 piston all the way up in the cylinder. Dropped camshaft sensor in with the window at about a 10 or 11 o'clock position. The cap was installed turned clockwise until it went 0 volts, turned it counterclockwise to 7.5 volts then back to 0 volts.The sensor was bolted down and fuel pressure is at 43lbs but no go. Car spins and small pops (not loud and not like backfire) like its trying to crank. Then all of a sudden it hits hard cranking like high timing or something. The timing comes from the chip and not the cam sensor if I am correct. The sensor does not have to be set with the window facing a certain or way does it. Crank reluctor ring is going through the crank sensor. So what in the hell is going on guys please help.
