ok i pulled my engine out and brought it to the shop..
the main bearing had stuff run through them and scrathed up the crank.. already 10\10.
now it needs to be turned 20\20
is this ok to still run?? i mostly street drive and occasionally track it, 25+ psi...
should i go steel or try to find another stocker??
now the bearings? the machinst says he can only get .20 bearings in a regular version no race ones available??
any tips advice etc which way to go???
still need to measure the cylinder walls, but the pistons (stockers) still look good... fingers crossed...
