Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
Looks like MAF dropouts too.
You can test for intake leaks by getting a 3" rubber cap for drain pipes at Home Depot and putting a tire valve in it. Clamp it on the turbo. Take off the valve covers and the rocker arm shafts. Pump it up to 20 or so lbs and find the leaks. Could be clamps, intercooler, doghouse, vacuum lines but you'll find something somewhere. As far as the drag radials go I'm good with 20 lbs. Lower than that doesn't help, makes it worse really.
