Cross Flow user Look in here
  • Thread starter Thread starter AsphaltAnihil8r
  • Start date Start date
A
AsphaltAnihil8r
Guest
So how do you like the Cross Flow exhaust
Lounder than a Single Shot?
Louder that Hoofer Cat back with Ultra Flows?
Easy to instal?
is it Stainless Steel?
Would you buy one again?
Well thats all for now!!:D :D
I have one in my car. I consider it loud but my car is not a daily driver. The single shot is way louder and drones like a SOB. My hooker with maxflows which are similar to ultraflos was lots quieter than either.
easy to install , sure if it drops right in.;) A second set of hands is very helpful.
Cross flow
I run a cross flow on both of my cars, I am very pleased with the sound. Louder then stock but a lot quiter then the hooker cat back system with the super comp muffs. No droning either.
Fit was like a glove. I also polished up the tips to a chrome finish. Those 3 inchers look cool.
Tom:cool:
Sounds great and looks tough w/ the 3" tips....however, don't buy it if your expecting "silent operation". I have a small drone at about 2400.....which is highway cruising in o/d.
...as for fit....I'd agree with the two hands...I did it alone, but alot of tightening/loosening-readjust-repeat.....
I barely drive it and really don't care too much about noise...heck....I'd even run an open pipe :)
jmtc
Mark
jmtc
Mark
How would you compare with all the other systems that drone ,,I havent had a system yet that didnt drone,
I want less drone not too loud but good flow,,is there a system out there????:(
I have a hybrid system with 3"DP, Random cat, ATR 2 1/2" and Hooker Aerochamber mufflers. No drone and very quiet. I am going to try another aerochamber in place of the cat to improve flow. I think the muffs flow pretty well, as you can see right through them inlet to outlet.
Obviously, the quieter you go, the less likely for drones to occur. However, I should make sure you understand that I only get a good drone when the windows are up and the radio is off.....and the radio doesn't have to be loud to drown out the background noise otherwise.
Overall, I'd say the exhaust is very reasonable for the amount of flow your getting. Of course, drones are influenced heavily by engine build (mods, heads, cams, etc).
Mark
I like mine. It is a little loud but quieter than my 2-1/2" Hooker dual with muffler replacement pipes and a single 3" Pitbull at the cat. The installation was the easiest TB installation I have ever done. The exhaust was litterally on in under a half an hour with 1 other guy helping. I used band clamps at the test pipe/downpipe connection.
Those of you who have the crossflow, can a Wolfe sway bar setup be installed?
I have 2 friends with the Crossflow and 2 with the 2.5" dual, but I've never heard the 3" single shot. Both of the prior sound great in my mind, but there is some drone... not that I care, that's the least of my worries (bad windw & door seals, etc.).
I wish I had one of them on my car, my cat back is VERY restrictive and I'm really getting tired of taking my test pipe off every time I go to the track. The two guys with the 2.5's haven't seen any difference in performance between running the full exhaust and with the dump open. Must flow good. With my junk exhaust I see a solid .15 when I open the test pipe. I really need to fork over the $ to get one of the ATR setups.
Hope this helps.
-Banning.
