Crossover pipe
MR2CHIPO
Hi all!!
Anyone know where I could find a crossover pipe to match my Poston headers? Currently running the stock pipe but it's leaking badly and its time to upgrade :biggrin: Went to gbodyparts.com and only saw 86/87 pieces. Thanks in advance for the anticipated help!!
tough call... usually the stock pipes held up well with the postons headers... Someone might have an ATR pipe laying around... Post in the forsale/wanted section, wait a day or two and see what comes up... Just make sure you post it is a hot air!
Also, dont look at just what Brian has at Gbodyparts online... Call him and he will gladly sniff aorund his shelves for ya!
John:)
you need to determine if the flanges on the headers are ovaled or the DP.If a good stocker will fix it I probably have a good one .85 crossovers are differant
As I was ready to remove my xover pipe I saw a trail of oil leaking from above the oil filter. Turns out the oil pressure sensor was loose!! Tighten it and it solved the oil leak and the anoying pfiff, pfiff sound that I misdiagnosed as a leaking xover pipe :-). Thanks to all that replied.....problem solved
