Cruise inop
TurboWh1
Hey guys,
Is there an easy way to figure out why my cruise is not working? I thought it was the turn signal/cruise switch because the wires appeared to be frayed but I just replaced it with a new oem switch and it did not fix it. Is the any flow charts out there on how to test the cruise system? Any ideas would be helpful!!
Thanks,
Brandon
Make sure the vacume line on top of the DS valve cover is plugged in - that was my issue.
Figured out our issue today, it is the brake pedal/switch out of adjustment. Not sure how to adjust for this. Not sure what to adjust when looking up behind the pedal. The info on the link in this thread is not helping me see what and where to adjust so the plugs work correctly when the pedal is pushed down. This is clearly our issue, we eliminated all the other items and it worked when I pulled the pedal up with my foot confirming the diagnosis. Thanks for your time.
