turbo39151
anycoloraslongasitsblack
- Nov 7, 2002
Ok here it is... I have an 86 GN that came with out a radio. I installed an Alpine CDA 9847 but did not like the look so, I pulled it out and installed a CSII deck that should have come with the car. When I bough the car it was a basket case and had lots of questionable wiring. I fixed everything.
I had first though of installing a nicer set-up using Xtant speakers, and amps.
I purchased a set of Xtant Xis 2.5, 100 watt, 5.25" 4ohm Bi-amp woofer/tweeter speakers for the doors; Xtant 404M 4channel 400w amp; and a 12" Xtant sub (diamond style, can't recall part number)
When I redid the car, I shaved the antenna and have poor radio reception but I have addressed that with a hidden antenna. I rarely drive the car and even more rarely use the radio as I like to listen to the turbo whine
I was thinking that I'd just go back to stock but I wonder if it would be worthwhile to upgrade at all. I think I'd be fine with the simple 6 speaker system with no sub but I have a set of PAC SNI 35's if I need to install.
Please bear in mind I am not a pro or even good amatuer installer. I know how to do wire most stuff but I am not a guru. That is why I am asking on this section.
Basic tunes is all I need. Can I purchase a set of CSII speakers that are not blown for a reasonable price or are they now too "rare" and expensive that I should go and buy the new age upgraded stuff. I know I can use my Xtant doors but I do not know what is compatible with them for the dash and rear...
Any input is appreciated.
